5.1 & 5.4 AP's
ive noticed motorola now has these two products out now. Have any of you guys used these yet? how do they compare coverage wise to 5.2 or 5.7? if these have the better coverage with a 5.7 we may look into getting some of these. any info is appreciated.
EDIT:
I did some researching and it seems that 5.2 is limited to 200mw EIRP and 5.7 is limited to 800mw EIRP and 5.4 is apparently limited to 1w EIRP. Yet the product descriptions for all 3 i can find say 1w. is this a misprint ?
nobody’s using either of these? hm.
are reflectors allowed in this spectrum?
You can always increase the receive gain as long as the transmit power is turned down enough to not go over the FCC limits.
5.2. and 5.4 are limited power systems.
You will not get the same distance as w3ith 5.7
edited
edit
Thats out of topic…i bet.
Yeah, I really don’t see how that has anything to do with the question or topic.
I agree - irrelevant and inappropriate.
thanks this was the answer i was looking for. i finally found the products specs on motorolas website. which now after the redesign are buried :roll: and a total PITA to get to.
