5.2 Slave rebooting/losing power frequently.UPDATE
I found out what was causing my 5.2 BH link so many problems… The master BH was receiving sync via timing port. When I switched it to Generate or Receive from Power, it stabilized. Before, the RSSI/Power would jump back and forth from -48dbm to -60dbm, and the link tests showed 85%. This is a LOS link .4 miles apart. All is good now.
Zach
Why is my 5.2 BH losing power or rebooting every 1.5 hours or so? Has anyone ever seen anything similar? I checked the spectrum and there is NO other 5.2 gear in the area. Checked the cable. The Master does not have any problems. LOS. NO reflector or dish on either BH. This is the event log for today. The customer has the Power Supply pluged into a APC UPS w/ batt. backup. Will try swapping out Power Supply’s, even though this one is new. Thanks for any help.
5.2GHz - BackHaul - Timing Slave - 0a-00-3e-00-ca-6a
Software Version CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
Software Boot Version CANOPYBOOT 3.0
FPGA Version 062403 (DES)
Uptime 00:14:25
System Time 15:59:55 11/07/2005
Ethernet Interface 100Base-TX Full Duplex
Subscriber Modem Stats
Session Status REGISTERED
Registered AP 0a-00-3e-00-ca-85
RSSI 1238 (-65 dBm) Will jump from this to 2000 RSSI and -48 Power level. Jitter 2
Air Delay 50 (approximately 0.46 miles (2450 feet))
00:21:59 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
00:21:59 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 68 Max ExtInt 452 Cur DecInt 33 Max DecInt 33 Cur Sync 35 Max Sync 56 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 2 Max FEC 185 Cur FPGA 67 Max FPGA 301 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
00:21:59 UT : 11/07/05 : File root.c : Line 888 System Startup
00:21:59 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
00:21:59 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
00:21:59 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
00:21:59 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
00:22:45 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
01:31:24 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
01:31:24 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 70 Max ExtInt 458 Cur DecInt 49 Max DecInt 33 Cur Sync 34 Max Sync 54 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 2 Max FEC 173 Cur FPGA 68 Max FPGA 306 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
01:31:24 UT : 11/07/05 : File root.c : Line 888 System Startup
01:31:24 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
01:31:24 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
01:31:24 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
01:31:24 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
01:32:08 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
02:18:16 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
02:18:16 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 13 Max ExtInt 693 Cur DecInt 19 Max DecInt 33 Cur Sync 6 Max Sync 69 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 294 Cur FPGA 13 Max FPGA 425 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
02:18:16 UT : 11/07/05 : File root.c : Line 888 System Startup
02:18:16 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
02:18:16 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
02:18:16 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
02:18:16 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
02:19:01 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
04:12:13 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
04:12:13 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 80 Max ExtInt 465 Cur DecInt 45 Max DecInt 33 Cur Sync 35 Max Sync 69 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 6 Max FEC 172 Cur FPGA 75 Max FPGA 304 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
04:12:13 UT : 11/07/05 : File root.c : Line 888 System Startup
04:12:13 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
04:12:13 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
04:12:13 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
04:12:13 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
04:12:56 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
06:17:14 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
06:17:14 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 8 Max ExtInt 559 Cur DecInt 18 Max DecInt 33 Cur Sync 4 Max Sync 60 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 228 Cur FPGA 8 Max FPGA 361 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
06:17:14 UT : 11/07/05 : File root.c : Line 888 System Startup
06:17:14 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
06:17:14 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
06:17:14 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
06:17:14 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
06:17:56 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
08:29:10 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
08:29:10 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 73 Max ExtInt 861 Cur DecInt 40 Max DecInt 33 Cur Sync 35 Max Sync 69 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 4 Max FEC 379 Cur FPGA 71 Max FPGA 509 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
08:29:10 UT : 11/07/05 : File root.c : Line 888 System Startup
08:29:10 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
08:29:10 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
08:29:10 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
08:29:10 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
08:29:56 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
09:41:32 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
09:41:32 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 107 Max ExtInt 801 Cur DecInt 27 Max DecInt 33 Cur Sync 20 Max Sync 49 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 36 Max FEC 373 Cur FPGA 77 Max FPGA 496 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
09:41:32 UT : 11/07/05 : File root.c : Line 888 System Startup
09:41:32 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
09:41:32 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
09:41:32 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
09:41:32 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
09:42:16 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
10:55:48 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/nibuf.c : Line 417 FatalError()
10:55:46 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
10:55:46 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 220 Max ExtInt 710 Cur DecInt 40 Max DecInt 33 Cur Sync 37 Max Sync 68 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 84 Max FEC 359 Cur FPGA 160 Max FPGA 435 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
10:55:46 UT : 11/07/05 : File root.c : Line 888 System Startup
10:55:46 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
10:55:46 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
10:55:46 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
10:55:46 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
10:56:46 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
12:53:52 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
12:53:52 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 83 Max ExtInt 642 Cur DecInt 33 Max DecInt 33 Cur Sync 35 Max Sync 54 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 9 Max FEC 279 Cur FPGA 77 Max FPGA 421 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
12:53:52 UT : 11/07/05 : File root.c : Line 888 System Startup
12:53:52 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
12:53:52 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
12:53:52 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
12:53:52 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
12:54:36 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:10:52 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:11:22 UT : 11/07/05 : File httptask.c : Line 618 Reboot from Webpage.
13:11:16 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:11:16 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 28 Max ExtInt 606 Cur DecInt 25 Max DecInt 33 Cur Sync 0 Max Sync 54 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 10 Max FEC 251 Cur FPGA 18 Max FPGA 385 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
13:11:16 UT : 11/07/05 : File root.c : Line 888 System Startup
13:11:16 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
13:11:16 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
13:11:16 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
13:11:16 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
13:12:40 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:52:02 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:54:45 UT : 11/07/05 : File httptask.c : Line 618 Reboot from Webpage.
13:54:32 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
13:54:32 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 0 Max ExtInt 599 Cur DecInt 39 Max DecInt 33 Cur Sync 2 Max Sync 51 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 314 Cur FPGA 0 Max FPGA 350 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
13:54:32 UT : 11/07/05 : File root.c : Line 888 System Startup
13:54:32 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
13:54:32 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
13:54:32 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
13:54:32 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
13:54:09 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
00:00:00 UT : 01/01/00 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
00:00:00 UT : 01/01/00 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset
00:00:00 UT : 01/01/00 : File root.c : Line 888 System Startup
00:00:00 UT : 01/01/00 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
00:00:00 UT : 01/01/00 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
00:00:00 UT : 01/01/00 : File root.c : Line 903 FPGA Version : 062403
00:00:00 UT : 01/01/00 : File root.c : Line 907 FPGA Features : DES
14:08:00 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
14:14:35 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
15:44:51 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
15:44:51 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 914 System Reset Exception – External Hard Reset WatchDog Cur ExtInt 63 Max ExtInt 651 Cur DecInt 29 Max DecInt 33 Cur Sync 26 Max Sync 50 Cur LED 0 Max LED 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 4 Max FEC 268 Cur FPGA 59 Max FPGA 400 Cur FrmLoc 0 Max FrmLoc 0 AAState 0
15:44:51 UT : 11/07/05 : File root.c : Line 888 System Startup
15:44:51 UT : 11/07/05 : File root.c : Line 893 Software Version : CANOPY4.2.3 Jul 23 2004 11:13:49 BH-DES
15:44:51 UT : 11/07/05 : File root.c : Line 897 Software Boot Version : CANOPYBOOT 3.0
15:44:51 UT : 11/07/05 : File root.c : Line 903 FPGA Version : 062403
15:44:51 UT : 11/07/05 : File root.c : Line 907 FPGA Features : DES
15:45:38 UT : 11/07/05 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1055 Time set
could be a faulty unit,
swap it out and see what happens, swap it around with the other pair, put the slave where the master iis and the master where the slave is
try changing the master to slave and slave to master
I would suggest bringing the BH's up to 7.1.4 and the latest FPGA. Then post the event log again after bringing it up to 7.1.4.
See first post above.
bump
bump
The posts above said 4.2.3, I recommended 7.1.4. Did I miss something?
bump
No, i just wanted to let the forums know what fixed my problem. We are keeping the bh’s at 4.2.3. No need to upgrade when there isnt a problem!
