im working on an rf problem @ my main site for a bh. when i run a specturm test everything is @ -60 or worse except for 5715 and 5720. I cant select these freqs on the configuration menu but i saw something about a hidden menu with additional freqs.
anyone know how to do this?
Looks full, you might try a different freq.
go to http://your-ip-address/configuration.html to find this “hidden” frequencies. Careful. Power level will not be the same after you change them. If the link is weak, it may not connect at all
