May be a dumb question but i need to know who is right
If i have 5.7 sm that is on a normal reflector dish what is the total db output of that antenna? and how did you come up with that number?
i see the dish is a gain of 17 db and the radio is 8db (i think) so is the total output 25db??
thanks
no one???
Table 15 in Canopy System Release 11.2 (http://www.cambiumnetworks.com/support/ … /index.php)
“7 dBi internal + 18 dB reflector” for 5700 BH, SM (PMP 100, PTP 100)
Other cases are depicted in the Table.
Hope it helps.
BR.
thanks
