5.7ghz AP and SM speed issue
Hi, I’m using the above units as a point to point(one AP to The single SM) the problem I have is speed. I’ve got 11mbps at the AP but only getting 1-1.5mbps at the SM. Jitter at 4 up and downlink efficiency’s at 100%. Any help would be greatly appreciated. Thanks Bryce
How are you measuring your performance? Link test tool within the SM or another application like iPerf?
Used the link test on the SM then we used speedtest.net to check down/up speeds. Thanks for your reply and questions! :slight_smile:
