Hi
all my network is composed by SM with 8.2.2 and NAT+DHCP enabled.
The Private NAT IP of the SM is 192.168.11.1. So, normally, the first pc will get 192.168.11.2 and so on.
NAT Public Network: 10.21.0.0/16
Radio Public Network: 10.20.0.0/16
Some of the customer (2 actually) had connectivity problems.
When I check the arp table of their SM I get the following:
Telnet+> arp -a
IP Address Physical Address iface pend c-time l-time
10.20.0.3 00-0d-b9-12-6c-19 rf2 N 44206 51950
10.21.0.2 00-05-1c-04-00-4a et1 N 3514 0
192.168.11.3 00-01-4a-c2-6b-1c et1 N 3499 26402
245.121.12.41 a0-45-be-00-01-8e et1 N 1322 1322
192.168.104.1 1a-00-3e-52-a0-45 rf1 N 1182 1193
127.0.0.1 4c-50-42-41-43-4b lo0 N 1182 1193
192.168.11.2 00-01-4a-c2-6b-1c et1 N 921 921
255.255.10.0 00-00-00-00-ff-ff et1 N 921 1619
NAT ARP Table
10.21.0.2 00-05-1c-04-00-4a NAT N 3985 50394
10.21.0.203 00-0c-42-14-b4-8f NAT N 3499 4810
10.21.0.1 00-40-f4-bc-1e-61 NAT N 3478 37815
The same data are visible using web interface.
The strange thing are the two IP: 245.121.12.41 and 255.255.10.0.
Did anybody has the same issue?
Ciao
Massimo
