Motorola does make a 5.7Ghz SM with adjustable power correct? So far the only SMs I’ve seen have the Transmit Output options of Normal and Low.
Also, does anyone know what those are in dBm?
pcpolo,
The PMP430 has a setting on the AP released in 11.1 which allows you to give tell the AP what the SM’s target receive level in dBm. This then uses APC to set the output power of the SM.
Are you asking about Canopy FSK radios (PMP100)?
Tom
Correct, I’m referring to the PMP100 models.
For the 100/200 series, adjustable transmit power should be available on P10 and newer hardware.
