I was just wondering if its better to have the 6.0 Compatibility setting disabled or enabled on my 900MHz AP’s? Everything is running 7.3.6 and are hardware scheduled.
Cheers.
I disabled it and did not see any difference in performance.
I have to assume there is some subtle improvement as whatever processing power was allocated for the 6.0 compatability is not used.
