I have seen reference to a 120 degree antenna for the 900 mhz AP, but I can’t seem to find one on line to get a description or price. Can some one point me to a url where I might find some specific information. Thanks.
not sure of the url but do a google search on TIL-TEK
spiker wrote: I have seen reference to a 120 degree antenna for the 900 mhz AP, but I can't seem to find one on line to get a description or price. Can some one point me to a url where I might find some specific information. Thanks.
Check out this one. I bought this one and it works 5 miles at 100 feet
http://www.pacwireless.com/products/SAH9_DataSheet.pdf
I recommend the use of the MTI 120. http://www.mtiwe.com/search.aspx?parent … 0&search=1
The Til-Tek is also a good option and you can contact last mile gear for those at www.lastmilegear.com
i also recommend the MTI 120 - the 12.5 db model. we have two of those on a tower and have gotten 13 and 16 miles respectively - just on customers who have requested service. no telling how far we could establish a link if we were just going for distance.
we have used til-teks a couple of times. probably the best we have ever seen performance wise.
