For a 450i 900Mhz PTP link is it a requirement to use two C009045B001A or can one be used in conjunction with a normal SM (C009045C001A)?
You have to buy the PtP radios to connect to each other. A PtMP SM will not work as a slave.
Thanks Eric!
