900 uplink speed
We have played around with the 900’s ALOT. The best we can get is about 430k up. Has anyone been able to do better?
We have tried 50%, double rate, etc.
I see anywhere from 400k to 800k. What are their sustained and burst speeds set at? This particular customer was set at 800k and 1500k.
Stats for LUID: 4 Test Duration: 5 Pkt Length: 1522
Downlink RATE: 3467673 bps
Uplink RATE: 702873 bps
Downlink Efficiency: 99 Percent
Max Downlink Index: 100
Actual Downlink Index: 99
Expected Frag Count: 33864
Actual Frag Count: 33924
Uplink Efficiency: 98 Percent
Max Uplink Index: 100
Actual Uplink Index: 98
Expected Frag Count: 6864
Actual Frag Count: 6944
I routenely see 900 MHz throughput similar to this:
Stats for LUID: 2 Test Duration: 2 Pkt Length: 1522
Downlink RATE: 2247168 bps
Uplink RATE: 1880320 bps
Downlink Efficiency: 100 Percent
Actual Downlink Index: 100
Expected Frag Count: 8778
Actual Frag Count: 8778
Uplink Efficiency: 100 Percent
Actual Uplink Index: 100
Expected Frag Count: 7345
Actual Frag Count: 7345
I have my upload/download radito set to 50%
Is this with 2x rate active for the uplink?
That link test I posted was with 2x enabled, yes.
Here’s another customer, this one is not 2x enabled.
Stats for LUID: 4 Test Duration: 2 Pkt Length: 1522
Downlink RATE: 1123840 bps
Uplink RATE: 1017344 bps
Expected Frag Count: 4390
Actual Frag Count: 4390
Expected Frag Count: 3974
Actual Frag Count: 3974
How/or are you rate limiting them? What do you have their sustained/burst rates set at?
Status and Speed Test for my radio (no limit on speed). We are not using 2x rate - we have had problems with that.
Device Information
Device type 900MHz - Multipoint - Subscriber Modem - 0a-00-3e-90-01-9c
Software Version CANOPY 7.2.9 Jul 23 2005 01:49:03 SM-DES
Software Boot Version CANOPYBOOT 3.0
FPGA Version 070605 (Single, 40MHz ExtBus, DES, Sched )
Uptime 00:17:00
System Time 10:03:07 11/27/2005
Ethernet Interface 100Base-TX Full Duplex
Subscriber Modem Stats
Session Status REGISTERED VC 20 Rate 1X/1X
Registered AP 0a-00-3e-90-26-68
RSSI 1647
Jitter 1
Air Delay 214 (approximately 5.96 miles (31458 feet))
Radio Slicing Value 528 (decimal)
Radio Transmit Gain Setting 14 (decimal)
Radio Power Level -66 dBm
LUID 4
IP Address 192.168.101.4
Registration Grant Status Normal
Sustained Uplink Data Rate 20000 (kbps)
Uplink Burst Allocation 500000 (kbits)
Sustained Downlink Data Rate 20000 (kbps)
Downlink Burst Allocation 500000 (kbits)
Frame Configuration Information
Data Slots Down 16 +
Data Slots Up 6 +
Control Slots 0
Site Information
Site Name
Site Contact
Key Features Information
Maximum Throughput Unlimited
Downlink RATE: 1634304 bps
Uplink RATE: 596736 bps
Expected Frag Count: 6384
Actual Frag Count: 6384
Expected Frag Count: 2331
Actual Frag Count: 2331
What am I missing - I have NEVER seen 1mb speed test between the SM and AP. I’d love to see 800-1000k up.
I'm using BAM for rate limiting. That peticular customer is set to 512k sustained upload and download, and 1024k burstable upload and download.
It is my understanding that the Link Test does not take into account any kind of bandwidth limiting. It is a raw test of the RF throughput from AP to SM.
Jerry: There are a couple of setting you could check.
Looking at your frame info, it seems that you are not dividing your slots evenly between up and download:
Data Slots Down 16+
Data Slots Up 6+
Control Slots 0
I'm running:
Data Slots Up 11+
Data Slots Down 11+
Control slots 1
What's your max range set to? Setting a high(er) max range reduces the number of frame slots available to use.
What's your Downlink Data % set to?
Also, look in "RF CB Stat" under Expanded Stats of the AP. Are you getting any indiscards or outdiscards? If so, you should add a control slot.
Hopefully something in there will shed some light...
Changed ratio to 50% and added 1 control slot - that did it. Seeing 800-900k both ways.
Right now we are on a single T1, but we have negotiated for a 5M pipe so it will be interesting to see what we can squeeze out of a 900. We have some 2.4’s and 5.7’s and i am sure that those will scream. Too bad I have this clump of trees in the way…
Thanks for the help.
I’m gald that cleaned things up for you.
That will be cool once you get your 5 mbps pipe to the backbone. We’re in the process of negociating a frac DS3 straight to the local backbone. I can’t wait.
Life is good (my new favorate t-shirt brand),
Andy
jerry what kind of problems are you having with 2x?
