Can someone help me with how downlink % and QoS setting in the 900 AP affect the speed at a SM?
Richard
The 900AP has roughly 4 Mbps aggregate of useable throughput. Setting this setting for example to 75%, should provide 3 Mbps DL, 1 Mbps UL to the SM. The QoS setting in the AP takes priority over the QoS setting in the SM. If you set this on the AP, this will sepecify the max data rate and burst for each SM that is registered to the AP. Depending on the application normally this setting on the AP is left as default, and you will want to adjust the QoS setting on the SM based on your tiered services.
In addition to this, something that is commonly misunderstood is the “Burst” setting. This is not a speed, but rather an amount that the SM can transmit or receive at full air rate before falling back to the sustained rates. The manual covers this in more detail if you want to know more about the bucket mechanism, etc.
we have our radios set to 79% DL and a max range of 9 miles… this seem to have given us about 300k extra performance… not much but every little bit helps
Current Results Stats for LUID: 5 Test Duration: 2 Pkt Length: 1522
Downlink Rate: 3672576 bps (3.67 Mbps)
Uplink Rate: 808960 bps (808.96 kbps)
Aggregate Rate: 4481536 bps (4.48 Mbps, 367 pps)
Pkt Xmt (Act/Exp): 604/0 (302 pps)
Pkt Rcv (Act/Exp): 131/0 (65 pps)
Downlink Efficiency: 100 Percent
Downlink Index (Act/Max): 100/100
Frag Count (Act/Exp): 14346/14346
Uplink Efficiency: 100 Percent
Uplink Index (Act/Max): 100/100
Frag Count (Act/Exp): 3160/3160
VC 21 Rate 2X/2X
Mgthump,
At what distance is your furthest out customer? Just curious.
jakkwb
8.3 miles at 71db
