900mhz power
So we are deploying 900mhz canopy. I would like to keep the spectrum clean by turning power down. The problem is Im not all that familiar with 900. I dont see wny sort of ATPC option in this (which amazes me its not there).
So whats the best way to ensure the coverage we are shooting for, but keep the poer only at neccessary levels? The AP Im pretty confident is a set and forget issue, but what about the SMs? Is powering down something best done at install, or remotely after the link is hardened?
Must learn balance grasshoppa… :slight_smile:
viewtopic.php?t=2827&highlight=balancing++levels
wow, I followed these steps on our failed 2.4 deployment, It cleaned up jitter an re-regs across the board. If only I knew this when I started
