90degree Sectors at 900MHz
What do you all use? We’ll be looking for some HPOL sectors in a few months. We’ve been using MTIWE 180degree sectors for about a year now and the performance has been superb, however the sheer size of these units makes me worry about mounting difficulties when we need to upgrade.
If anyone has dealt with these before, how difficult was it to mount them and what kind of performance are you getting? Do you have any suggestions or alternate antenna recommendations?
Thanks in advance.
we only have one 90 degree 900 mhz sector but its a til tek and it rocks. yes it may be larger but its definately high quality stuff.
Assuming you’re using the dualpol antenna? I didn’t notice a hpol 90degree sector from them.
wifiguy wrote:
Assuming you're using the dualpol antenna? I didn't notice a hpol 90degree sector from them.
yea we have it set in HPOL
Based on my experience with MTI, I would not use anything else.
