access or block some sites
their 're sites which i can't get to
why is tha.? pmp1000,  settings: pppoe
Cant get to them at all or just slow? Slow I think MTU size might come into play.
If you dont use PPPOE and can do a straight bridge with the CPE will those sites work? Try to narrow down if its a PPPOE issue or something else?
Do all your PPPOE users ave the same issue?
