Access Point using Elevate license
Just upgraded to 3.5.1 today and synced up 3 new Access Points.  I know I only have 1 elevated SM, but my license is showing 5 in use.  It looks like it is counting the SM and my 4 APs.  Anyone else seeing this behavior?  I thought the license was per SM only.  Using flexible licensing.
We will check that scenario.
1 Elevate device is allowed to be registered on AP in case License is exceeded or there is no license/ Licensing ID entered on AP at all.
I can assume “in use” counter has summarized them from each AP.
Thank you.
Thanks, Fedor.  I look forward to your findings.  If you need more information, please let me know and I will try to get it to you ASAP.
My test setup contains 2 APs.
1 Elevate License was activated for Cloud Licensing which is assotiated with appropriate Company.
Licensing Portal is reporting correct number of used Licenses.
Is it possibble more than 1 Elevate radio is registered on your APs?
Thank you.
