What does an amber light mean on a power supply? It started off with a green light but switched to the amber color.
Not sure but I would guess low or high voltage?
What if you disconnect the SM, does the light turn green?
Is the SM still working?
The SM would not work. Switched power supplies and the SM worked?
What is the voltage output on the power supply?
