Can you have both advantage and non-advantage ap’s in a cluster with a CMM?
I don’t see why not.
Well i guess you can do it, the only one suggest is that in the AP anvantage you put HARDWARE SCHEDULE AND in the normal AP you put Software schedule…
You will have to use the Frame calculator in R6.1 then.
