I noticed that after the recent changes in cnMaestro, after hotspot restart, the parameters saved in the advanced settings are not applied?
You have to enter manually, select the indicated channel again and only then it is applied.
It’s so weird that it used to work fine, and now it just stopped working. After every reboot you have to manually change everything as if the settings didn’t exist
Please have a look at it.
AP e410, soft 4.2.3-r2
@PFR
Config parameters which are configured in Advanced settings will get applied. Could you please confirm the sync status when parameters are added in the ‘advanced settings’? It should be ‘Not In Sync.’ If not, then the configuration parameters are not being saved.
Can you please let me know which version of cnMaestro you are currently using?
It wasn’t a problem recently.
I noticed this after the last cloud update.
on my e410, after restarting, it always gets up to DFS channels, even though it has channel 48 permanently entered. If you want, I can give you access to the cloud.
Status is “in sync”
Maybe it’s an isolated case? Or maybe a mistake - I don’t judge.
cnmaestro version 4.0.1-r8
Yes @PFR, please provide Raja/me access to the cloud so that we can investigate the issue.
ashok.kumar@cambiumnetworks.com / raja.muniyandy@cambiumnetworks.com
Gentlemen, I found the problem.
It’s embedded in the firmware. When set to outdoor, the system cuts out NON-DFS channels completely. Shouldn’t it be like that?
sh wireless radios channels PL
Shows:
e410-parter(config)# sh wireless radios channels PL
Interface: radio1 Country:PL
CHANNEL MAX-POWER EIRP MAX-POWEREXT
1 15 20 0
2 15 20 0
3 15 20 0
4 15 20 0
5 15 20 0
6 15 20 0
7 15 20 0
8 15 20 0
9 15 20 0
10 15 20 0
11 15 20 0
12 15 20 0
13 15 20 0
Interface: radio2 Country:PL
100 25 30 0
104 25 30 0
108 25 30 0
112 25 30 0
116 25 30 0
120 25 30 0
124 25 30 0
128 25 30 0
132 25 30 0
136 25 30 0
140 25 30 0
COMPLETELY MISSING NON-DFS CHANNELS?
Manually changing to channel 48 from advanced mode will switch to the NON-DFS channel.
Something’s wrong here
Yes @PFR, under Poland regulatory, when the device placement is set to “Outdoor,” the AP will only operate in DFS channels as those are the supported outdoor channels in the country.
Can you please confirm whether the e410 AP allows the configuration of channel 48 or other indoor channels using config override? Because when the placement is set to ‘Outdoor’, the AP should not allow the configuration of indoor channels, even with a config override. Instead, it should throw an error(like below)
Well, that’s cleared up
Thank you for your help
