Advantage AP's
Hello
My customers only need a max of 4mbps
Is there any other advantage of using the advantage AP’s?
:slight_smile:
Well, it wont take many customers at high speed to wish you had an Advantage AP. Also, it is lower latency which is better for VoIP or gaming
Paul McCall
PDMNet Canopy Repair
658 Old Dixie Highway
Vero Beach, FL 32962
772-564-6800
Thanks, Pretty much what I though, needed it confirmed tho, its alot of $$$ replacing 40 of them!
:slight_smile:
Under 40 users you can get away with a standard AP.
The Advantage AP’s give you the 2X capability which increases the AP efficiency.
Jerry Richardson wrote:
The Advantage AP's give you the 2X capability which increases the AP efficiency.
BTW be aware that RF signal must be higher to get benefit from 2X
