What is the key length required for AES 128 encryption?
If I’m disable the encryption at AP and the subscriber should go down ? But in cambium radios still the data is flowing while AP side key is disabled and subscriber side enabled! It’s strange for me with cambium! As AES symmetric encryption the key is identical both side and if key is disabled one side that data should not flow further., If I’m wrong correct me
