After upgrade 8.2.1 2X is no longer working [long Post]
After upgrading all my network to 8.2.1 the 2X act like disabled. also the site name desapeared from the session status:
-STATUS AP-
5.4GHz - Access Point - 0a-00-XX
Device Information
Device Type : 5.4GHz - Access Point - 0a-00-XX
Software Version : CANOPY 8.2.1 AP-DES
Software BOOT Version : CANOPYBOOT 3.0
Board Type : P9
FPGA Version : 100207
Uptime : 23:30:34
System Time : 00:23:39 10/21/2007
Last NTP Time Update : 00:23:04 10/21/2007
Ethernet Interface : 100Base-TX Full Duplex
Access Point Stats
Registered SM Count : 18
GPS Sync Pulse Status : Receiving Sync
Site Information
Site Name : XX
Site Contact : XX
Site Location : XX
Key Features Information
MP Double Rate : Enable
Advantage Radio Status : Advantage
-SESSION STATUS AP-
LUID: 002 : MAC: 0a-00-XX(Lite SM) State: IN SESSION (Encrypt Active)
Session Timeout: 0, AirDelay 172 (approximately 1.60 miles (8428 feet))
Session Count: 8, Reg Count 2, Re-Reg Count 10
RSSI (Avg/Last): 377/385 Jitter (Avg/Last): 5/4 Power Level (Avg/Last): -78/-78
Sustained Uplink Data Rate (DL): 256 (kbit)
Uplink Burst Allocation (DL): 768 (kbit)
Sustained Downlink Data Rate (DL): 256 (kbit)
Downlink Burst Allocation (DL): 768 (kbit)
Low Priority Uplink CIR (DL): 0 (kbps) Low Priority Downlink CIR (DL): 0 (kbps)
Rate : VC 18 Rate 1X/1X
LUID: 003 : MAC: 0a-00-XX State: IN SESSION (Encrypt Active)
Session Timeout: 0, AirDelay 155 (approximately 1.44 miles (7595 feet))
Session Count: 10, Reg Count 10, Re-Reg Count 0
RSSI (Avg/Last): 1170/1156 Jitter (Avg/Last): 1/1 Power Level (Avg/Last): -52/-53
Sustained Uplink Data Rate (AP): 20000 (kbit)
Uplink Burst Allocation (AP): 500000 (kbit)
Sustained Downlink Data Rate (AP): 20000 (kbit)
Downlink Burst Allocation (AP): 500000 (kbit)
Low Priority Uplink CIR (D): 0 (kbps) Low Priority Downlink CIR (D): 0 (kbps)
Rate : VC 19 Rate 1X/1X
-GENERAL STATUS SM LUID03-
5.4GHz - Subscriber Module - 0a-00-3e-51-be-57
Device Information
Device Type : 5.4GHz - Subscriber Module - 0a-00-3e-51-be-57
Software Version : CANOPY 8.2.1 SM-DES
Software BOOT Version : CANOPYBOOT 1.0
Board Type : P10
FPGA Version : 092707
PLD Version : 9
Uptime : 00:23:41
System Time : 00:21:21 10/21/2007
Antenna : Vertical
Subscriber Module Stats
Session Status : REGISTERED VC 19 Rate 1X/1X
Registered AP : 0a-00-3e-50-0b-1b
RSSI : 1309
Power Level : -47 dBm
Jitter : 1
Air Delay : 155 approximately 1.44 miles (7595 feet)
Region Codes
Regional Code : Other
Site Information
Site Name : XX
Site Contact : XX
Site Location : XX
Maximum Throughput : 7 Mbps Aggregate
Advantage Radio Status : Non-Advantage
-EVENT LOG SAME SM-
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 417 System Startup
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 422 Software Version : CANOPY 8.2.1 SM-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 426 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 436 FPGA Version : 092707
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 440 FPGA Features : DES, Sched
12:53:03 UT : Sat Oct 20 2007 : File src/syslog.c : Line 1283 Time set
23:57:14 UT : Sat Oct 20 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
23:57:14 UT : Sat Oct 20 2007 : File src/sockintf.c : Line 119 FatalError()
23:57:14 UT : Sat Oct 20 2007 : File src/stack_dump.c : Line 143
Stack Dump information:
Current context Task: SOCK
Current Stack: 2%
Max Stack: 19%
Task Stack Dump:
0x00751fa0: 0x00001fa4 0x00752000 0x0079a620 0x0074f4b4
0x00751fb0: 0x00000bff 0x0003000d 0x0071239c 0x0071245c
0x00751fc0: 0x00000000 0x00000000 0x00000000 0x00000000
0x00751fd0: 0x00000d05 0x01200200 0x0000f7cf 0x00000000
0x00751fe0: 0x00000000 0x00000000 0x00000000 0x007524b0
0x00751ff0: 0x00000122 0x00000920 0x534f434b 0x00000000
0x00752000: 0x00000000 0x00751fa4 0x00000226 0x00002ffc
0x00752010: 0x0000001d 0x0000006b 0x00000000 0x534f434b
0x00752020: 0x00000000 0x00000021 0x007c329e 0x00190e8c
0x00752030: 0xffffffff 0x0075203c 0x00048f28 0x0011f9ec
0x00752040: 0x00000077 0x00000000 0x00045a0c 0x00000000
0x00752050: 0x00000001 0x0042190c 0x00d82800 0x00045cd0
0x00752060: 0x00000000 0x0075210c 0x00000010 0x00000001
0x00752070: 0x0042190c 0x0042190c 0x00d82800 0x00047bd4
0x00752080: 0x0042190c 0x0075210c 0x00000001 0x00e05d34
0x00752090: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520d0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520e0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520f0: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752100: 0x00000000 0x00000000 0x00000000 0x00000010
0x00752110: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752120: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752130: 0x000cddcc 0x00000000 0x0075239c 0x007523f8
0x00752140: 0x00752454 0x00000000 0x00000000 0x00000000
0x00752150: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752160: 0x00000000 0x00000000 0x00177ff8 0x00000000
0x00752170: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752180: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752190: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521d0: 0x00000000 0x00000000 0x00000000 0x00000001
0x007521e0: 0x330eabcd 0x1234e66d 0xdeec0005 0x000b0000
0x007521f0: 0x00000000 0x00000000
Return Addr: 0x0011780c
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception – Watchdog Reset
2X is enabled in the configuration of the SM I have also double checked that all the requisites for 2X are met. It have been working before on the same link.
My questions are:
1 when the AP if of the SM goes in SCANNING VC 0 1X/1X shouldn’t that be 2X/1X ?
2 why the site name in the session status is gone?
3 I have SM as config source why does it say that the rate is configured from the ap
20000(AP)
4 What is the exception? (aprox every 6-8 h) is that the automatic reboot from ethernet if lock?
Anybody with similar problem? (At least one of them)
I am having this problem with 8.2.4 but only on ONE P10 ap. same dump and everything. I know this post is old, but is there an answer?
Thanks!
we have solved the issue reverting all settings to default and reconfiguring it back again.
Hope this helps
