AirMagnet E430W and E502s
Hi.
I was downloading antenna patterns for E-series devices and couldn't find for 430W and E502S. Are they on Support page? I can't see them...
Greetings!!
You can download the antenna patterns for E430W and E502S Ekahau (.xlsx) and IBWave (.VEX) using following Link:
https://support.cambiumnetworks.com/files/e410/#r3
https://support.cambiumnetworks.com/files/e400/
If you are looking specifically for Airmagnet (.ant) files let us know.
Best Regards,
Gupta
Yes, I am looking specifically for Airmagnet files.
Hi
We are working on this, will keep you updated.
Best Regards,
Gupta
Please find the attached E502S antenna patterns for airmagnet. I will get back to you with E430W antenna patterns.
Best Regards,
Gupta
Thank you.
Hi.
Just checking for AirMagnet files for E430W/H and the new E700. Could you please upload them to support page?
Kind regards
EDIT: Also E501s files would be great to have. Thanks
Hi AnzeZ
Please find the attached E501S airmagnet antenna patterns. For the remeaing models you can download the Ekahau antenna files in .xlsx format and convert them to .ant file as per the document attached.
Let me know if you need any more details.
Best Regards,
Gupta
