Antenna Dbi
What gain antenna should I use for a distance of 110km over water using?Trying to use the back hauls to connect 2 islands.
What radios are you using?
Over water? :shock:
OS Spectra
I have several links using the same dish the furthest being 127.1km or 79.5 miles should work for you.
Gabriel QFD4-52 4ft Dual polarized Quickfire Parabolic dish 34.7dBi gain.
is this link over water?
