Is there a specification for antenna with part number: N060082D128 The file allenyu posted is not available any more... Also I can't find antenna smaller than 1,2m on Andrew page for 6GHz band.
Kind regards
EDIT: Just found smaller than 1,2m, but not sure if that's the correct antenna specification for the one I am looking for. Is it possible to publish somewhere all specifications, so we can rather focus on client than searching for specifications? -no hard feelings here.
attached is the spec sheet of the N060082D128A dish. The smallest dish in 6 GHz is a 3' dish so that would be about 0.9m. I'll have to defer to Allen, our PTP820 product manager, on publishing dish specs somewhere. In the meantime if there are other dish specs you're looking for let me know and I can attach them.
Our problem is that for every 'project' - PTP link - we have to send antenna specification, with registration for frequencies. Searching for specifications and losing time with it, doesn't make sense for me.
You can reach out to me direct by email at brian.chan@cambiumnetworks.com and I can supply the necessary spec sheets as necessary. Let me double check with PLM if I can just send them all to you or if he can publish them somewhere.
Thank you for your help. If they can upload all to Support page, that would be great! In the mean time, if I am going to need additional specifications I will send you e-mail.
