Is there any plan to provide 10 MHz channel size?
Best regards
Antonio
Its on the roadmap but does not have a targeted release yet.
I’d like to use your product as an alternative to expensive equipment WIMAX to 10 MHz. I hope to include this option in the next release. Good luck in the development and promotion of the desired product.
+1 for 10mhz channels and release of 3.6ghz range of epmp.
+1 for 5-45mhz of channel options. Also would love to see 3.65 (50Mhz) and 900mhz.
I like to see a 3,3 -3,8 GHZ Version with 7+10Mhz channel support, to use as inexpensive Wimax equipment.
