We had a 450m rebooting due to an error we have never seen before, Has someone else noticed something like this on their APs?
******System Startup******
System Reset Exception -- User Initiated Reset
Software Version : CANOPY 21.0 AP
Software Boot Version : CANOPYBOOT 1.0
Board Type : P14
Device Setting : 5.7GHz MU-MIMO OFDM - Access Point - 0a-00-3e-60-5b-d8 - 5735.0 MHz - 20.0 MHz - 1/16 - CC 176 - 2.5 ms - Other Regulatory/Other
FPGA Version : 0c0379;
03/16/2022 : 02:31:30 UTC : File ucos_ii/src/common/psos_wrap.c : Line 1040 :GPS Date/Time Set;
03/16/2022 : 02:33:41 UTC : File ucos_ii/src/common/psos_wrap.c : Line 1107 :Time Set
03/16/2022 : 02:33:59 UTC : Acquired sync pulse from Timing Port (UGPS/cnPulse)
03/16/2022 : 02:34:09 UTC : File devices/fpga/src/fpga_device_driver.c : Line 191 :Board Temperature: 21 C / 69 F
03/23/2022 : 16:25:37 UTC : Lost sync pulse from Timing Port (UGPS/cnPulse)
03/23/2022 : 16:25:37 UTC : File cmdline/src/gps.c : Line 5857 :Sync Pulse History [1/5/15 min]: Sync%[91.67%/98.34%/99.45%], SNR[33.25/32.40/32.81], Visible[20.00/20.00/19.95], Tracked[15.00/14.50/14.76]
03/23/2022 : 16:25:37 UTC : Generating Sync - Free Run
03/23/2022 : 16:43:53 UTC : Acquired sync pulse from Timing Port (UGPS/cnPulse)
04/01/2022 : 14:17:27 UTC : Lost sync pulse from Timing Port (UGPS/cnPulse)
04/01/2022 : 14:17:27 UTC : File cmdline/src/gps.c : Line 5857 :Sync Pulse History [1/5/15 min]: Sync%[93.34%/98.67%/99.56%], SNR[33.50/34.25/34.85], Visible[17.00/17.00/18.01], Tracked[16.00/15.25/14.85]
04/01/2022 : 14:17:27 UTC : Generating Sync - Free Run
04/02/2022 : 09:51:14 UTC : File mips64/src/stub.c : Line 207 :Fatal Error
04/02/2022 : 09:51:14 UTC : File mips64/src/stub.c : Line 222 :Backtrace:
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x100071cc]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x1056f230]
04/02/2022 : 09:51:14 UTC : [0x7fff7018]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x104d869e]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x1042cd74]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x104bba14]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x104bc45c]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x104bcb0c]
04/02/2022 : 09:51:14 UTC : /opt/cambium/canopy() [0x1056bf14]
04/02/2022 : 09:51:14 UTC : /lib32-fp/libpthread.so.0(+0x78d8) [0x7713d8d8]
04/02/2022 : 09:51:14 UTC : /lib32-fp/libc.so.6(+0xe90cc) [0x76e170cc]
01/01/2020 : 00:00:01 UTC : File Startup : Line 0 :
01/01/2020 : 00:00:00 UTC : File ucos_ii/src/common/psos_wrap.c : Line 1107 :Time Set
System Reset Exception -- Watchdog Reset due to process: canopy
Board Type : P14
01/01/2020 : 00:00:12 UTC : File ucos_ii/src/common/psos_wrap.c : Line 1040 :GPS Date/Time Set;
04/02/2022 : 09:54:44 UTC : File ucos_ii/src/common/psos_wrap.c : Line 1107 :Time Set
04/02/2022 : 09:54:57 UTC : Acquired sync pulse from Timing Port (UGPS/cnPulse)
04/02/2022 : 09:55:07 UTC : File devices/fpga/src/fpga_device_driver.c : Line 191 :Board Temperature: 18 C / 64 F
