We usually set our APs downtilt at either 1 degree down or pretty much level. We figure with the angle the APs put out there is not much of a need to put much downtilt. What has everyone else found out?
i have found that putting a back tilt on my SM’s works the best…maybe i should downtilt my AP’s
The only stuff we even put downtilt on is our long-range 900 gear. Everything else is level. We adjust the SM to compensate for the elevation change.
