Hello
in MONITOR WIRELESS of an AP, it should be SUPER to see the SW version of the CPE STA.
Hello
Thank you for great idea.
I would be grateful if you could duplicate this in Idea section to take it tracked:
http://community.cambiumnetworks.com/t5/Your-Ideas/idb-p/Ideas
This functional is already availble in cnMaestro, which allows you not only to see FW vesion of each SM registered on AP, but also perform mass upgrade or mass configuration using templates.
Thank you.
It also takes the name of the app in the sm and here it is recorded, please insert this monitor, for us it is very important
