I have been trying to make some AP - SM links only 4 sucessfull but, when i go 1.5 km distance or more fail. I would like to know if some of you have a link further thant 1.5 km. when using.
AP Advantge 5.7
SM 5.57 with Reflector.
Regards :twisted:
We have 45 km with 5.4 Ghz. Advantage AP, SM with RD27.
We have hundreds at 8km, dozens at 13km, and a few at 16km.
Make sure that the max distance setting in the AP is more than a mile (= 1.6km). That could cause a major problem.
Set it to just beyond your furthest SM. This will keep a handle on speeds and latency.
If you will be deploying a bunch, then set a distance that you want to install out to. I typically set mine to the max for everthing except 900 mhz. That is usually limited to 40 miles.
Finally we did it.
Thanks you all! :lol:
What did you do???
