When running an AP spectrum analysis, your results will be poor if its co-located with other access points, as the TX energy from these near field devices will show up in large swaths of spectrum.
Make it possible to run an AP based spectrum analysis where the device is only in RX mode during GPS sync’d receive windows. This will show you a clean spectrum analysis result.
If using a beamformer based multiple AP antenna system, this is actually necessary to prevent damage to the AP radio during spectrum analysis.
Thanks for your message.
This is a great idea.
Can you please post it to the "Idea" section above?
http://community.cambiumnetworks.com/t5/Your-Ideas/idb-p/Ideas
