I have two 5.2 access points that after configuration will now not boot up tried to overide them with a 6 pin rj-11 plug and still nothing any help would be appreciated and in unrelated news i have pics of what an ap cluster looks like after direct contact with lightning its not pretty.
by not boot up- do you mean that the sync and ethernet led’s don’t come on?
or can you simply not access them? the default plug should allow you to get in with the 169.254.1.1 255.255.0.0 settings.
check your default plug on another unit.
