aPMP2000 not working on aPMP3000 and ePMP3000
I have a ePMP3000 radio connected to a APMP3000 90 sector antenna, and also the APMP2000 smarth antenna but the radio says “Smart Antenna is Not Connected, Power Off”. I did already set “Forced Smart Antenna” and did test two New Smarth antennas but none worked. The cables are properly connected.
well, that is not so good but i guess i should cross the cables tomorrow :frowning:
We’ll see how long it works…
Great info brublbe1
I will let you know how it goes.
Thank you so much.
Yes, they are labeled correctly (H goes to H, and V goes to V) but they are physically laid out on opposite sides, and so the cables need to (non-intuitively) physically cross in order for H=H and V=V. :woman_shrugging:
Yep, you are right too ninedd,
a Cambium engineer have just sent me this picture minutos ago.
I will execute this task soon.
Thank you all guys :smiley:
Yep!! It works now :smiley:.
Let’s see how long… :thinking:
Thank you all.
