Hola comunidad,
Podrían indicarme que flujo debería seguir en los cursos de aprendizaje?
Saludos.
Hola comunidad,
Saludos.
Hello - you can start Connecting U this way: Cambium Connecting U is available through the Cambium Learning portal at:https://learning.cambiumnetworks.com. If you are new to Cambium Learning, you will also need to register for a Cambium ID, and you can do so at https://support.cambiumnetworks.com/register.
