greetings community
I currently have a question, I have a basic cnmaestro account that is, it is not premium and since it only allows me 9 aps and 17 Sm after 17 aps these are added "but after a certain time (15 or 20 days) they are reset to factory mode Is this normal? I have this situation in 2 aps that I configured as such for a pmpt lately and they lose configuration
It is not an cnMaestro issue.
This is problem with power supply on the AP (in my opinion)
Reset to default is typical when somone play with power supply
That doesnāt sound normal.I have a couple of customers still left on basic cnMaestro with 500ās and 180ās and they never hit issues like these.
Maybe someone from Cambium can chime in
Like @PFR says I think you might have some sort of power issue going on.
I appreciate the information
but it has already happened to me with 2 aps of the same model in different places, I donāt think thatās a coincidence
change the power supply by one to see if the fault persists, these sources are not touched by anyone and they are new
This isnāt a cnMaestro thing - it doesnāt erase the config of you donāt pay for it.
I canāt say if it is a power issue, or defective gear, or what your problem is⦠but I can say for sure that itās not a cnMaestro āfeatureā
In my implementations, I have such situations in places where there are power āspikesā, then the device restarts to the default settings. Another situation is, for example, lightning in the area. Another situation is the use of power tools nearby and the sudden power off after a power outage.
The easiest way is to buy a power strip with voltage stabilization. Plug in for 2 weeks and see what the symptoms will be.
When the reboots are over, the problem will be solved, if not, you make an RMA request and replace the devices with new ones.
