Can I use a PTP670 ATEX/HAZLOC radio in one end of the link having a non certified PTP670 in the opposite site?
Will not be over-the-air or traffic problems? Are they compatible
Thanks in advanced
Thanks in advanced
The PTP 670 ATEX/HAZLOC radio won’t establish a link with a standard PTP 670 radio. Unfortunately, you’re going to have to use ATEX/HAZLOC at both ends of the link, even if only one end is in a hazardous environment.
Thanks a lot Mark, you have saved my day.
Could you please help me to clarify the following two related questions?
Is it necessary to use some type of special coaxial cable and N connectors for the connection between the connectorized PTP670 ATEX/HAZLOC radio and an external antenna? Or maybe I can use the typicall coax cable generated by LINKPlanner? RDN5785 - 3M (9.8FT) SUPERFLEX RF LOW LOSS JUMPER CABLE
The connectorized PTP670 ATEX/HAZLOC radio must used ATEX certified antennas as well? or typical antennas can be used?
Thanks in advanced
Hi Jorge. There are no special ATEX/HAZLOC restrictions on RF cables and external antennas. You can use the typical cables and antennas recommended by LINKPlanner.
Dear Mark,
Thanks a lot for your kind help. I will do as you suggested
