We've been using auto-update in our office to standardize the f/w version on SMs going out into the field, but we're running into a snag. CNUT 4.12.8, AP is running 16.0.1 Official, but my 450b Mid-Gain SMs running 16.0 from the factory don't ever update. Is this just me? Has anyone else seen this?
There are possible workarounds, but all require a massive increase in effort to get the radios updated. Anyone have any idea?
Update: here is a section of the CNUT log from yesterday and today - I was not seeing any of these errors yesterday when I wrote the above:
05/14/19 16:00:04 INFO Enabling SM Autoupdate on Selected Network Elements process has completed.
05/15/19 08:16:11 INFO Refresh Selected Network Elements process start ..
05/15/19 08:16:11 INFO Refreshing NE at:10.1.48.76
05/15/19 08:16:11 INFO NE at:10.1.48.76 refreshed.
05/15/19 08:16:11 INFO Refresh Selected Network Elements process has completed.
05/15/19 08:16:18 INFO Updating Selected Network Elements process start ..
05/15/19 08:16:18 INFO CANOPY160_1BUILDOFFICIAL_PXP45x_S.pkg3 loaded.
05/15/19 08:16:18 INFO Starting Update Process ..
05/15/19 08:16:18 INFO Queue NE:10.1.48.76 for updating
05/15/19 08:16:19 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Checking Network Element Status
05/15/19 08:16:19 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Current = CANOPY 16.0.1 AP, CANOPYBOOT 1.0, 020519
05/15/19 08:16:19 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Using Package C:\Users\Darren\Downloads\MotoCambium\CANOPY160_1BUILDOFFICIAL_PXP45x_S.pkg3
05/15/19 08:16:19 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Disabling Auto-Update
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Auto-Update Disabled.
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Transferring Files actionList.acl;5x_cat120.img; to host:10.1.4.5 by http
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Enabling Auto Update...
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003EA03255@10.1.4.5,Auto-Update Enabled
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003E783B1C@AP:[10.1.4.5]LUID:[3],Auto-Update Started(status:120).
05/15/19 08:16:20 WARN Failed to find Element in update queue:0A003E783B1C@AP:[10.1.4.5]LUID:[3],Invalid image(s) selected Or Failed to set max file size(status:256).
Darren - We will look into this for you... I can't think of anything off the top of my head. Someone smarter than me will reply as soon as we find something.
Darren- Did you check Update--> Configure to see if the PMP 450b was selected in the Auto Update SM Type. I ran the autoupdate from 16.0 to 16.0.1 with no issue. Looking at your log messages it was missing the image.
Yours:
Mine:
Transferring Files actionList.acl;5x_cat120.img;upgrade.img;upgrade-p15.img; to host:10.120.200.22 by http
My PMP 450b was connected to a PMP 450i AP. What AP are you using. An engineer brought to my attention that if using a PMP 450 AP it may not have enough memory for all the images. Can you try selecting one radio model at a time? I have may lab set up for something else at this time. If you are using a PMP 450 I can see if I can test it.
Dave - that's why I respect you so much, man! You saw the actual potential issues and limitations which could cause this result, and figured out how to work around them.
Yes, that was it! The 450 AP has limited RAM, so to make it have no issue when auto-updating, I need to load only the necessary images. Much obliged!
