Hello,
Is there any comparison matrix between Autopilot and CnMaestro features? In order to know which CnMaestro features are not available in Autopilot mode
Many thanks,
Jesus
Hello,
Many thanks,
Jesus
@jesusolivas wrote:
Hello,
Many thanks,
Jesus
Autopilot basically makes all the features available on one standalone AP, available across a group of APs all managed together from a single console. And it builds on that with enhacements to network visibility such as Insights, Timeview and a network-wide dashboard.
The features that require cnMaestro today (fully customized captive portal, vouchers, payment gateway, social login) are not available in Autopilot.
Many thanks
AutoPilot | cnMaestro Cloud |
One AP acts like a WLC | Cloud version of WLC |
Can manage upto 32 Access Points | Can manage upto 10 thousand Access Points |
Used in Smaller deployments | Used majorly for large deployments |
Can be enabled by making one AP as Master | Can be used via visting cloud.cambiumnetworks.com |
All Access Points must be in the same network | Access Points can be in different networks |
Member Access Points gets discovered automatically in the same network | Access Points needs to be onboarded and then approved |
Limitations on creating Splash page | Fully customizable Splash page for Captive Portals |
Many thanks
You can always use the above comparison table for your ready reference.
