Backhaul dropping (GPSs MISS) after swapping 1000AP with 3000L
So this is a micropop that consists of :
1000AP Lite Omni<----> F200 Backhaul Slave <~~TDD PTP 20Mhz channel 5510Mhz ~~> F200 Backhaul Master
AP is 20Mhz Channel at 5805Mhz TDD 75/25
BH is 20Mhz Channel at 5510Mhz TDD PTP
This site has run without any problems for a couple of years. Today in prep for installing the 11th CPE (it's a 1000 Lite so 10 CPE limit)  I went up the pole and swapped the 1000AP Lite with a 3000L....  The 3000L is configured exactly like the 1000, same 20Mhz channel same 5805 TDD 75/25.
As soon as the 3000L came up the backhaul started randomly dropping the link... the position of nothing changed, the backhaul radio wasn't touched physically or remotely. The enclosure wasn't even opened, all I did was go up the pole (opposite side the BH is mounted on even) disconnect the 1000 and replace it with the 3000L. Now this from the BH:
Jun 19 13:24:03 BHS-MPH02 kernel: [14540590.630000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:40:28 BHS-MPH02 kernel: [14541575.150000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:40:57 BHS-MPH02 kernel: [14541603.950000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:42:32 BHS-MPH02 kernel: [14541698.820000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:42:42 BHS-MPH02 kernel: [14541709.150000] SM disassociated from AP[00:04:56:21:e7:b4] F=5835 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:43:27 BHS-MPH02 kernel: [14541754.050000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:44:45 BHS-MPH02 kernel: [14541831.990000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:44:59 BHS-MPH02 kernel: [14541846.270000] SM associated with AP[00:04:56:21:e7:b4]
Jun 19 13:45:02 BHS-MPH02 kernel: [14541849.320000] SM disassociated from AP[00:04:56:21:e7:b4] F=5835 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:45:41 BHS-MPH02 kernel: [14541888.550000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:48:13 BHS-MPH02 kernel: [14542040.430000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:49:00 BHS-MPH02 kernel: [14542087.570000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:51:20 BHS-MPH02 kernel: [14542227.110000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:52:17 BHS-MPH02 kernel: [14542283.950000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 13:55:37 BHS-MPH02 kernel: [14542484.510000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 13:55:59 BHS-MPH02 kernel: [14542506.450000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 14:00:19 BHS-MPH02 kernel: [14542766.290000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 14:01:06 BHS-MPH02 kernel: [14542813.570000] SM associated with AP[00:04:56:d5:3f:dd]
Jun 19 14:09:03 BHS-MPH02 kernel: [14543290.640000] SM disassociated from AP[00:04:56:d5:3f:dd] F=5510 11naht20. Reason: 33 (GPFs MISS)
Jun 19 14:09:37 BHS-MPH02 kernel: [14543324.080000] SM associated with AP[00:04:56:d5:3f:dd]
Any ideas other than to stop using 3000L's ?
Could you please send Tech Support file from AP to me please?
It would help to understand the reason of the drops.
Thank you.
