Backhaul for E500
Is is possible to use the i450 PMP to backhaul multiple e500 on the 5 Ghz band?
Are you asking if you can use an 450i's RF connection to connect wirelessly to an E500? If that is what you're asking, then NO, you cannot do this as each of these radios uses different communications methods.
Yes sir.
Best Regards.
Kevin Cedeno F.
NPO and EPC Wireless Engineer
EWPE - Ericsson LTE Certified Engineer
MWFE - Motorola Wireless Field Engineer
Landline: +593 97-952-2253
Mobil WS : +593 98-896-8995
Landline EUA: +1 (518) 712-9466
Ecuador - Guayaquil
United States - California
Unless you try to do something beyond what you have already mastered, you will never grow.
I read the question slightly differently: It is possible to backhaul an E500 data via the PMP450i SM, by connecting the data out cable from teh E500 to the PMP450i SM and then using that to transmit to a PMP450 AP.  Hope that helps
