Fellas I need to backhaul over about 60KM of water, has anyone done this before,I am looking at the new 300Mbps backhauls, has anyone used them yet? Feel free to give suggestions.
i would recommend looking at the higher gain antennas and using 30/60mbs BH unless you need 300mbs throughput.
You Will need Four Antennas six feet each one, (radiowaves), Two Antennas at each point . at that distance i doub that you can make a 300Mbps Link. maybe a 100 to 150 Mbps. You need to send the Two coordinates at Your Motorola Reseller and they can send you exact requeriments.
