Bam Questions
I have bam server setup and here is the customer
Session Status
REGISTERED
Registered AP
0a-00-3e-20-01-7d
RSSI
1431
Jitter
2
Air Delay
107 (approximately 0.99 miles (5243 feet))
Radio Slicing Value
414 (decimal)
Radio Transmit Gain Setting
19 (decimal)
Radio Power Level
-69 dBm
LUID
14
IP Address
10.17.3.14
Registration Grant Status
Normal
Sustained Uplink Data Rate
10000 (kbps)
Uplink Burst Allocation
10000 (kbits)
Sustained Downlink Data Rate
256 (kbps)
Downlink Burst Allocation
40000 (kbits)
However the values are not correct if I go in and rescan the ap the customer will get the right value which is below
Session Status
REGISTERED
Registered AP
0a-00-3e-20-01-7d
RSSI
1431
Jitter
2
Air Delay
Radio Slicing Value
414 (decimal)
19 (decimal)
Radio Power Level
-69 dBm
LUID
14
IP Address
10.17.3.14
Normal
256 (kbps)
256 (kbits)
256 (kbps)
40000 (kbits)
This doesnt happen in all the customers but I have seen some where they get the wrong vaule from the bam server. I do rescan and it gets the right value then in a day or so its back to the wrong vaule. Any help?
i havnt seen this happen, but maybe on your AP you have it set as "Authentication Optional"
It should be set as “Authentication Required” when using BAM.
also make sure the AP is set to use BAM instead of SM for the configuration source…you will find this under the AP’s configuration page near the top.
Authentication is set to required.
And is also set to Bam Only[/quote]
