Bam or AP problem?
Ok here is the situation,
Customer on AP using bam,
Will pull the correct vaules set in bam.
All looks good, Few hours later,
Device type 2.4GHz - Multipoint - Subscriber Modem - 0a-00-3e-20-03-80
Software Version CANOPY 7.3.6 Oct 24 2005 12:06:56 SM-DES
Software Boot Version CANOPYBOOT 3.0
FPGA Version 051104 (Single, 40MHz ExtBus, DES, )
Uptime 29d, 03:21:01
System Time 01:19:42 02/02/2006
Ethernet Interface 100Base-TX Full Duplex
Subscriber Modem Stats
Session Status REGISTERED
Registered AP 0a-00-3e-20-02-2b
RSSI 1952
Jitter 2
Air Delay 71 (approximately 0.66 miles (3479 feet))
Radio Slicing Value 505 (decimal)
Radio Transmit Gain Setting 20 (decimal)
Radio Power Level -64 dBm
LUID 2
IP Address 10.26.3.2
Registration Grant Status Normal
Sustained Uplink Data Rate 20000 (kbps)
Uplink Burst Allocation 20000 (kbits)
Sustained Downlink Data Rate 128 (kbps)
Downlink Burst Allocation 40000 (kbits)
Customer ends up with the wrong upload vaules?
Should be as set in Bam
Sustained Uplink Data Rate 128 (kbps)
Uplink Burst Allocation 40000 (kbits)
Device doesnt drop connection or rereg.
Second Notice,
Same problem as first,
Different customer on different AP with Auth Disabled.
Customer is rebooted and pulls the correct vaules,
Device type 2.4GHz - Multipoint - Subscriber Modem - 0a-00-3e-20-94-52
FPGA Version 020205 (Single, 40MHz ExtBus, DES, )
Uptime 13d, 21:33:02
System Time 03:30:04 01/20/2001
Registered AP 0a-00-3e-20-0b-a5
RSSI 1710
Jitter 1
Air Delay 63 (approximately 0.58 miles (3087 feet))
Radio Slicing Value 333 (decimal)
Radio Transmit Gain Setting 19 (decimal)
Radio Power Level -44 dBm
LUID 2
IP Address 10.17.5.2
Sustained Downlink Data Rate 3500 (kbps)
Downlink Burst Allocation 500000 (kbits
Still wrong values even with out bam
Should be
Sustained Uplink Data Rate 35000 (kbps)
Uplink Burst Allocation 500000 (kbits)
Any Idea? Both are using 7.3.6 firmware and are hooked into Cmm Micros with no other issues
