Hi.
Another question: how can i determine a standard bandwidth to each SM that is registered on a specific AP.
E.g I have 2 SMs and i want the host behind them to have 1mb (768/256) bandwidth, I have read the user guide about the sustained uplink and downlink but when i run the link test it shows me the default bandwidth rate that i have determined on the AP
E.g 75% Downlink Data from 14mbps (11/3 mbps down/up).
Can anyone guide me how this is possible to be done? without using some kind of a tool (bam).
Thanks for your time.
you can adjust the speed on the SM if you configure the AP to allow it.
AP
configuration source = SM
SM
Speeds set on the config page as desired
you said:
SM
which parameters should i change the sustained downlink and uplink?
And if i change them how can i see if they had changed??
you see i configure the sm on sustained downlink 768kbps and uplink 256kbps but when i run the link test it gives me the values of the hole channel 14mb.
is there a way, exept the nms tools, to check if the connection of the SM with the AP is on 1mb???
thank for your help.
Try a web based speed test?
I _think_ software version 8.1 had an option to run the link test with/without configured sustained down/uplink.
(I could be wrong on that though - but I thought I saw it on the SM)
a link test wont reflect reduced speeds. like rjk suggested try running a speed test or check the speed on the AP session page.
Thanks for your help.
but i run cacti to see the limited bandwidth.
the last one shows that i have bandwidth limitation but it was easier with cacti.
