beacon missing problem pls help me
system_log.txt (9.7 KB)
Most frequently it is interference.
I suggest you to raise a support ticket. Our engineer will help you to isolate the issue.
“submit a request” on the right top:
https://support.cambiumnetworks.com/
Mohammad,
How is the signal level and SNR? use the e-align to get some real-time numbers.
This looks like there simply is not enough beacons being decoded to sync the SM to the AP and the most common reason is that the antennas are on side lobes and not getting a clean enough signal.
