Bell/Inukshuk show their faces
https://www.highspeedunplugged.sympatic ... ility.aspx
Note: no installation fees, supposedly they work up to 5km away from the Bell towers without even being mounted on the roof, if the brochure is to be believed. This is "pre-WiMaX" equipment according to Inukshuk, and the modem pricing is $250 per unit from Bell Sympatico.
Meanwhile, Motorola says they've discontinued software-scheduling capable units without actually releasing software v8 and the prices haven't come down much at all. Makes me raise my brows a little.
That v8 software you say it’s available for Canopy?? if so? when will it be ready to download ???
It was “supposed” to be available.
