Best configuration for wlan valn on cnpilot
Hello team
I am inquiring. Is it advisable to have the same network settings on the WLAN Vlan for cnPilot AP, for example creating VLAN2 on all APs, say 6 with 192.168.0.1 as the IP address and the same DHCP POOL.
Does it not affect the effectiveness of the seamless roaming?
@TimoWanume
Local DHCP server configured on each AP with NAT enabled - seamless roaming is not feasible.
Its not recommended deployment.
Kindly recommend a configuration where wifi users are not connected to vlan1 but still roam seamlessly
  • Configure external VLAN and DHCP server
  • Configure it as WLAN VLAN
  • Allow it on AP ethernet interfaces
