hi all,
i’ve a pair of bh 30 backhaul … my actual
Software Version is 5445-07-00
and my
Hardware Version is D05-R02-I
i’m finding some problem to lock modulation in transmit (on master) to the same modulation of receive
i’ve
Receive Modulation Mode 64QAM 7/8 (8.66 Mbps)
Transmit Modulation Mode BPSK 1/2 (0.73 Mbps)
someone can help me ?
i’ve RTFM
i can’t find upgrade for firmware on canopy site …
thank you all previously
It looks like frequency problem on one side.
Is your backhaul conectorized?
No it isn’t !
Then block the used frequencies and see what will happen.
erkan wrote: Then block the used frequencies and see what will happen.
they are locked :P
Then unlock everything. If you have APs on the same band turn them off for a test. Try to do better alignment and see the forum or the manual how to change the region code so you can use greater power. If this doesn’t help you will have to use that BH somewhere else.
erkan wrote: Then unlock everything. If you have APs on the same band turn them off for a test. Try to do better alignment and see the forum or the manual how to change the region code so you can use greater power. If this doesn't help you will have to use that BH somewhere else.
thank you i will try and i will refer to you !
thank you again
i cant’find how to change region code (in the manual is wrote that must buy a new license) is the only way ?
these are my data
Receive Data Rate 0.73,
Transmit Data Rate 8.66,
Receive Modulation Mode Detail
Restricted because of byte errors on the wireless link
Range
16.7
now i’ve one fixed channel for tx and rx (idfs create very much downtime) and using two frequencies is the same results. …
help me please !
thank you
sounds like lots of interference… what else is around??
Noise floor?
Try lo relocate the unit with problems.
moinavery wrote: sounds like lots of interference.... what else is around??
Noise floor?
There are many antennas (radio,tv and wisp)
this is the spectrum managment
some ideas ? :P
Lock all the frequencies except 5641, 5653 and 5689. You will have to do it on the master side.
My 5.4 BH30 has Max Transmit Power of 25 dBm, what is yours value for that?
erkan wrote: Lock all the frequencies except 5641, 5653 and 5689. You will have to do it on the master side.
i will try to lock that frequencies ....
power il locked to 25 too for me ... any ideas to increase ? ? :twisted:
You can’t increase that. Any good results now?
erkan wrote: You can't increase that. Any good results now?
i've an ap near that frequency
these are result before and aftere setting power output of that ap to 1 db
before
after
now i must change the frequency on ap ...
there is a metod to let's change the sm frequencies all in one step ?
thank you
You can use link http://www.motorolaptp.com/support/licensekey.php in order to get licence for other region in order to pull out max power from ptp400. We are using one of this as our main link to upper provider and it works solid as rock.
Canopy all over Montenegro!
what is the most powerfull region?
Is that Region 8?
mnet wrote: what is the most powerfull region?
Is that Region 8?
yes i think ... i've yet region 8 with power to 25 ....
other isp around seems to have more poer (like 2W)
:roll:
I see that you are using fixed frequency, change to Assymetrical DFS so that the radio would select the best channel
I have to BH60 on same tower, they were using auto DFS. I rebooted the whole equipment and both of them were on same channel using half of the best possible modulation. Don’t use DSF if you can avoid it.
erkan wrote: I have to BH60 on same tower, they were using auto DFS. I rebooted the whole equipment and both of them were on same channel using half of the best possible modulation. Don't use DSF if you can avoid it.
with dfs enable i'm experiencing very downtime ... i'm must organize my cluster now
i've
3 ap
2 bh 10
1 bh 300
1 bh 30
any help is appreciated ...
thank you
