BH20 rebooting every 5 minutes after upgrading to 8.1
Hi:
I have an extensive network deployed with Canopy. I really had no troubles, excellent devices, but after I upgraded one BH20 from 7.3.6 to 8.1 software this devices has been rebooting constantly every 5 to 10 minutes. I attach the event log, the version obtained via telnet, a latency graphic after upgrading and the information required by “CanopyRel81NotesIss1a” document.
How to solve this???
Thanks!
Version:
C A N O P Y
Motorola Broadband Wireless Technology Center
(Copyright 2001-2006 Motorola Inc.)
Login: root
Password:
Welcome root
Telnet+> version
Software Version : CANOPY 8.1.4 BH20-DES
FPGA Version : 041006
PLD Version : Unable to get PLD Version on platform 9
Frequency Band : 5.7GHz
Hardware Platform : 9
Hardware Minor Revision : 0
Device Type : CANOPY
Telnet+>
Event Log:
12:20:28 UT : 12/05/06 : File src/syslog.c : Line 589 System Log Cleared
12:23:33 UT : 12/05/06 : File src/syslog.c : Line 997 System Reset Exception – External Hard Reset Watchdog Reset
12:23:33 UT : 12/05/06 : File src/root.c : Line 409 System Startup
12:23:33 UT : 12/05/06 : File src/root.c : Line 414 Software Version : CANOPY 8.1.4 BH20-DES
12:23:33 UT : 12/05/06 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 3.0
12:23:33 UT : 12/05/06 : File src/root.c : Line 424 FPGA Version : 041006
12:23:33 UT : 12/05/06 : File src/root.c : Line 428 FPGA Features : DES Sched
12:24:37 UT : 12/05/06 : File src/syslog.c : Line 1099 Time set
12:29:34 UT : 12/05/06 : File src/syslog.c : Line 997 System Reset Exception – External Hard Reset Watchdog Reset
12:29:34 UT : 12/05/06 : File src/root.c : Line 409 System Startup
12:29:34 UT : 12/05/06 : File src/root.c : Line 414 Software Version : CANOPY 8.1.4 BH20-DES
12:29:34 UT : 12/05/06 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 3.0
12:29:34 UT : 12/05/06 : File src/root.c : Line 424 FPGA Version : 041006
12:29:34 UT : 12/05/06 : File src/root.c : Line 428 FPGA Features : DES Sched
12:30:38 UT : 12/05/06 : File src/syslog.c : Line 1099 Time set
12:35:35 UT : 12/05/06 : File src/syslog.c : Line 997 System Reset Exception – External Hard Reset Watchdog Reset
12:35:35 UT : 12/05/06 : File src/root.c : Line 409 System Startup
12:35:35 UT : 12/05/06 : File src/root.c : Line 414 Software Version : CANOPY 8.1.4 BH20-DES
12:35:35 UT : 12/05/06 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 3.0
12:35:35 UT : 12/05/06 : File src/root.c : Line 424 FPGA Version : 041006
12:35:35 UT : 12/05/06 : File src/root.c : Line 428 FPGA Features : DES Sched
12:36:38 UT : 12/05/06 : File src/syslog.c : Line 1099 Time set
12:41:35 UT : 12/05/06 : File src/syslog.c : Line 997 System Reset Exception – External Hard Reset Watchdog Reset
12:41:35 UT : 12/05/06 : File src/root.c : Line 409 System Startup
12:41:35 UT : 12/05/06 : File src/root.c : Line 414 Software Version : CANOPY 8.1.4 BH20-DES
12:41:35 UT : 12/05/06 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 3.0
12:41:35 UT : 12/05/06 : File src/root.c : Line 424 FPGA Version : 041006
12:41:35 UT : 12/05/06 : File src/root.c : Line 428 FPGA Features : DES Sched
12:42:39 UT : 12/05/06 : File src/syslog.c : Line 1099 Time set
12:47:36 UT : 12/05/06 : File src/syslog.c : Line 997 System Reset Exception – External Hard Reset Watchdog Reset
12:47:36 UT : 12/05/06 : File src/root.c : Line 409 System Startup
12:47:36 UT : 12/05/06 : File src/root.c : Line 414 Software Version : CANOPY 8.1.4 BH20-DES
12:47:36 UT : 12/05/06 : File src/root.c : Line 418 Software Boot Version : CANOPYBOOT 3.0
12:47:36 UT : 12/05/06 : File src/root.c : Line 424 FPGA Version : 041006
12:47:36 UT : 12/05/06 : File src/root.c : Line 428 FPGA Features : DES Sched
12:48:40 UT : 12/05/06 : File src/syslog.c : Line 1099 Time set
Information required:
Device Information
Device Type : 5.7GHz - BackHaul - Timing Master - 20 MBit - 0a-00-3e-f2-0b-37
Software BOOT Version : CANOPYBOOT 3.0
Board Type : P9
Uptime : 00:02:14
System Time : 12:50:23 12/05/2006
Last NTP Time Update : 12:48:40 12/05/2006
Ethernet Interface : 100Base-TX Full Duplex
Scheduling Type : Hardware
Graphic. I did the upgrade at 16:00.
Can you please call support to get this issue logged? I forwarded your post and some notes to tier 3 support so they are aware of it however they need to receive an escalation from tier 1 (the support center). You can either email or phone in, the contact info is in my signature.
The more information you provide the better. I would recommend running the “gather customer support” tool in CNUT. Make sure its ran on both BH’s.
Did you make sure the units were running Hardware Scheduling prior to the upgrade to 8.1.4?
