Hi
Is there a way to block devices with low signal levels from connecting to an R190 router?
For example any client device with a signal lower than -78 will be blocked from connecting, or will be kicked off.
If not can this feature be added?
Hi
I think someone asked this question recently and IIRC the cnPilot R series doesn’t have a cut off threshold, but the E series does. The E series has an SnR threshold you can define.
